Author Topic: Soundcloud Search  (Read 1859 times)
Trueplayer49
Hello!
I am new to using Musicbee and one of the main features I am interested in using is the SoundCloud search feature. However, I feel like I may have done something wrong or am not using it properly. When I use the search bar at the top right nothing happens. When I try to search via the bar, the message "Enter into the search box the title and/or artist of the track you want to listen to" disappears and nothing happens. I have tried to reinstall and tried this on a Different PC as well. I'm wondering if I am doing something wrong. I have also tried searching the forum before asking a question..
I know some work has been done recently, since after the last "official" release, to account for some changes on Soundcloud's end.  Try installing the latest patch for your version (probably 3.4, but check first) from here:
https://getmusicbee.com/patches/
Just unzip these files and overwrite the files in your current MB installation directory with files from the ZIP. (Note: This does not work with the Windows Store version).
Trueplayer49
@frankz Thank you! That actually fixed the issue.
