Author Topic: Disc Edition  (Read 1601 times)
jcquino
Hello
i use mp3tag to rename and organize my flac files in the way i needed, so i use the EDITION tag, but i cant find a way to display at musicbee. cant find that tag when tried to config panels. I even use custom#1 and turn it into edition, butg there is no show.
Hope someone can help me
thank you very much
Cheers
JC
Before you put it in a custom tag, you have to go one level deeper. Under Define New Tags you can set up the tag to be available to use in Custom Tags.
You can find more info here: https://musicbee.fandom.com/wiki/Custom_Tags
jcquino
Thank you very much ... it works fine now.
Cheers
