Author Topic: How do you add tag values from multiple songs? (Time x PlayCount)  (Read 2488 times)
SonicRings
I'm trying to be able to determine how much time I spent listening to certain songs based on multiplying their duration with the amount of times I played them. The Incredible Boom Boom helped me with the math part of it and I modified it to include hours in its display format here: https://getmusicbee.com/forum/index.php?topic=35695.msg195228#msg195228
However, I noticed that the play count it's using to multiply with the songs' combined duration remains static no matter how many songs I highlight. It keeps the first song's play count as the value and multiplies every other songs' durations by that value.
It treats every highlighted song as having, say, 3 plays, multiplying their lengths by 3, when in fact one could have 3 plays, another 6, and another 20.
How can I get it to calculate the songs' "time listened" using their own play counts? Here is the code I'm currently using:
$Split($Div($Mul($Add($Mul($Pad($Split(<Time>,:,1),2),60),$Split(<Time>,:,2)),<Play Count>),3600),.,1) hours $Mod($Split($Div($Mul($Add($Mul($Pad($Split(<Time>,:,1),2),60),$Split(<Time>,:,2)),<Play Count>),60),.,1),60) minutes $Mod($Mul($Add($Mul($Pad($Split(<Time>,:,1),2),60),$Split(<Time>,:,2)),<Play Count>),60) seconds
As you can see in the image above, it's using a play count of 1 for both songs despite the second song actually having 0 plays. The time listened it should be displaying is thus 4 minutes 29 seconds, not 7 minutes 19 seconds.
Last Edit: November 01, 2021, 11:18:49 AM by SonicRings
SonicRings
Is this the same question that you asked here:
https://getmusicbee.com/forum/index.php?topic=35695.0
and here?:
https://getmusicbee.com/forum/index.php?topic=3833.msg195206#msg195206
I'm trying to do the same thing yeah. I did already link to the first one so I'm not sure why you're linking that again lol. In the first one I was asking how to make the tag, now I'm asking how to make it work when highlighting multiple tracks.
This doesn't appear to be something that can be fixed from the user's side. As you noticed, for multiple files, MB does not treat <play count> the same way it treats <time>...difference being that the latter collects data from every selected track while the former only collects data from the first selected track. I don't know if that's intended or not. If it was not meant for <play count> to behave that way with multiple tracks, you can try reporting this as a bug. Then again, if it's intended to function that way, the only way forward for you would be to make a request for it in the wishlist section. Otherwise, I think you would miss out on that virtual tag of yours.
Last Edit: November 01, 2021, 11:35:59 PM by Mayibongwe
SonicRings
Good point. Yeah, I'm not sure whether or not it's intended either. I think I'll make a bug report later and if it indeed is intended I'll make a wish list request. Thanks for the suggestion.
Posted here: https://getmusicbee.com/forum/index.php?topic=35723.0
Last Edit: November 02, 2021, 04:28:14 AM by SonicRings
SonicRings
Now that <play count> incorporates values from all the selected files when selected files are displayed in the track info panel https://getmusicbee.com/forum/index.php?topic=35730.msg195426#msg195426 I'd like to once again post this question, as I'm encountering a small hiccup with it.
Look at the green text in the right panel. As can be seen, the top track's 15 plays gives it a "time listened" of 29 mins 30 secs, while the bottom track's 6 plays gives it 22 mins 6 secs. However, now that the play counts add up, the calculation is now taking into account 21 plays and a duration of the two tracks combined lengths.
In this case, the "time listened" of 1 hour 59 mins 0 secs divided by 21 yields 5 mins 40 secs, which is the addition of 1:58 and 3:41 (the product is rounded up by a second apparently).
So, I'd like to know if there is a way to basically remember/store the product of each track's duration * play count. In this case, it should add the products of each track's "time listened" together, which would be 22 mins 6 secs + 29 mins 30 secs = 51 mins 36 secs.
Any help is greatly appreciated!
Last Edit: February 06, 2022, 01:33:18 PM by SonicRings
