Author Topic: Taskbar hover-over for Musicbee does not show player controls in Windows 11  (Read 3067 times)
Night_Thastus
MusicBee: 3.4.7805
Windows: Windows 11 Pro, Version 21H2, Build 22000.282
Ever since upgrading to Windows 11, I have noticed that the hover-over for Musicbee is broken. It used to show pause, stop, play and previous/next song.
Now, it does not show any of these. Example:
This does not seem to happen 100% of the time, but it's definitely the majority.
EDIT: Image linking broken, here's the image: https://imgur.com/mK6iJIv[/
Coogan
It is working for me on Windows 11.
Hope you get it sorted out.
My MusicBee Version:
3.5.8878
spline
One more observation. The buttons reappear when I switch to a mini or compact player. The next time you restart the program, they are not visible again. :-\
spline
Update MusicBee to 3.5.8402 but no luck. Still buttons only reappear after player mode switch.
i cant reproduce any issues using your settings but have made a couple of changes, so could you try this version
spline
Thank you for taking the time to work on this. With the latest patch, the buttons appear after system reboot. Next if you open MusicBee - do NOT start music playing - wait for the taskbar pop-up - close MusicBee, the buttons begin to disappear on the third or fourth load. If you START playing music and then wait for the pop-up, buttons can start to disappear on 8-15 program load. I don't know how it actually works, but it looks like this taskbar popup is being cached somewhere or there is some kind of race condition.
All processing is in the GUI thread and i dont think there is any race condition but in any case could you try this version
https://mega.nz/file/t8NCHArK#SUjth7Uk1LU-9kwZC_q8ofyBi8bMZbn-YgDz4gakzDY
when the issue happens check the error log (help/ support/ view error log) and see if any cases of "parent handle=0" or "parent handle = 0 - error!"
spline
24.01.2023 18:26:51 - parent handle = 0 - error!
24.01.2023 18:26:51 - parent handle=38406518
One more thing. I'm using nas in a local network for my music library.
spline
