Author Topic: custom web links  (Read 6284 times)
cynflux
Hello,
It is possible to increase the number of custom web links to more than 10?
Thanks in advance.
cynflux
Ok, no problem.
Thanks for such an awesome program.
cynflux
Was it implemented before?
According to the following link, there were 14 search slots available.
https://getmusicbee.com/forum/index.php?topic=28882.msg160891#msg160891
I thought you were asking for another 10 on top of the 14 existing.
cynflux
Thanks for the reply.
My version of Musicbee only has 10 search slots. It is version 3.2.6626.
You need to update to the latest version as what you're currently using is about three years old. The change to 14 was made sometime after the 3.2 series.
