Author Topic: How do I stop musicbee substituting the path in internal playlists?  (Read 1755 times)
mrbenn
I have moved things around on my PC, one being moving the MB library to C:, which is an SSD and having done a "relink file paths" for the music itself none of my playlists are working after adjusting the playlist folder in settings.
Musicbee shows each filepath as
C:\Musicbee\FolderWithMusic\
which should be, and is shown in the .mbp when I open them in Sublime
M:\FolderWithMusic\
If the playlist file shows the correct path, how do I stop musicbee doing whatever substitution is going on when it reads these playlists.
For reference, the musicbee library + playlist files is in
C:\Musicbee\Musicbeelibrary\
and the music is on
M:\
edit: screenshot
Last Edit: October 25, 2021, 06:43:50 PM by mrbenn
mrbenn
I fixed it with a 2nd pass of "Relink File Paths" - it took 8 hours for the dialog to come up the first time so was hesitant to have t do that again.
Also clicking a playlist after a relink showed the correct paths, but clicking a *folder* of playlists sometimes showed the old, or a mix of old and new paths.
