Author Topic: Playlists (M3U) synced to SD card not able to import into BlackEx Player  (Read 703 times)
naifyboy
Hi all - looking for some help.
I have set up syncing to my SD card and all is well, but when I try and import the playlists into BlackEx player on my Samsung phone, it says "Failed to import cannot read the file" followed by "try a different file import manager" - have followed the advice from Blackplayer but to no avail.
Does anyone else have this issue?
Thanks
If BlackEx is saying to try another import manager, then the issue is with BlackEx as that is what's doing the importing. All MB is doing is exporting.
Two suggestions:
1- Try another format that BlackEx accepts. What format are you using now? What formats does it accept?
2- Try another player. GoneMad and PowerAmp both have the advantage that you can WiFi Sync between them and MB, using the MB WiFi Sync app.
Download the latest MusicBee v3.5 beta patch from here.
Check out the MusicBee Wiki.
How to post screenshots is here
