Author Topic: LineIn / Stream input - BASS_ERROR  (Read 1421 times)
emanresu
Hello!
I've tried multiple versions of MusicBee (even 3.4 patch) - ran it with admin and without - but I cannot get "Open Stream" -> "linein://" working,
either with a plugin or just this command. I desperately need to be able to route music into MusicBee,
how do I do this?
Thank you!
emanresu
I have used HTTP streaming with VLC locally and it works, although only with extremely low bit rates in FLAC, no direct RTSP or such.
When I add the stream as a new radio station it shows bitrate "945kb" whereas it works for 3 secs then stops,
or "886kb", and then the stream actually f*cking works.
emanresu
"868k" = 44.1 KHz,
"945k" = 48 KHz
I got it working by using FLAC again, 512kb (max limit, wtf?) and defaulting my buffer.
