UPDATE... See the
Solution below...
https://getmusicbee.com/forum/index.php?topic=35646.msg194924#msg194924So, haven't cared about Artist pics yet, but now I want my MP3s to be complete with both Front Cover and Artist pics, so was wondering how I get the Artist pics also embedded by MB?
Also, when I get them embedded MB won't go and "still" download and display them right?
I saw some talk about this in 2018 on the forum that someone's Artist pics were being overwritten by MB, for "display" anyway. Has this been fixed?
One reason I ask is because "some" of the images I'll want to change, so I don't want MB displaying another image.
Further, I would like to request that MB needs a "function change" in that NOTHING should be "automatic" unless we've manually set the setting to do so in Settings. Why? Because I had a serious problem with MediaMonkey in which even though they have a section in which you can set what tags are updated or not, and I set those settings, MM STILL downloaded and literally REPLACED all my tags. And they said it's "designed" to do this....
I was just trying to update Lyrics, and they said that on "save" ALL tags will be updated according to their database.... This was absolutely terrible, and I was trying to prevent just that in Settings, and had I not had a backup of my music files that hadn't been "fully" touched, I would have been in deep ****, manually fixing every single mp3, some 3,500, which I had already spent over a 100+ hours doing so manually using MusicBrainz Picard and Mp3tag...
Anyway, the reason I mention this is when I went into Artist Display in the Main Panel, and previous Theatre mode or whatever, I noticed Artist images were being "auto-downloaded". Now, it's good it's not "imbedding" them at least into the files, but something else should be done for auto-stuff, which will save some resources too. For example, if we want to use the Artist display, there could be a "note" at the top which indicates we need to activate auto-download for Artist Images in Settings.
Anyway, bottom line is I'm looking to embed Artist images into the song files. I noticed MB downloaded them all when I went to that view. Can I do that with MB, or is there another recommended method to do this by "auto"? Auto's fine for me in this particular instance for those particular empty "tags".
Thanks
P.S. Forgot to mention that I know about the Settings for Artwork retrieval and saving/embedding.
My big question is if I enable that, "what" Artwork is the program actually downloading and updating?
I don't want my Cover Art touched, or other Image tags, I just want to add the missing "Artist" Artwork?
