Author Topic: [Solved] Problem for having music on my ipod classic  (Read 5854 times)
robinwood
Hi, first thanks a loot for taking time helping people and for this software, amazing one!!! Working perfectly...almost ahahah
I've seen the topic for having music on my ipod (https://getmusicbee.com/forum/index.php?topic=18506.0) ,
problem is i can't have setting as before like this:
https://zupimages.net/viewer.php?id=21/39/jjmw.jpg
Musicbee think that it's like an hard drive:
https://zupimages.net/viewer.php?id=21/39/400e.jpg
but if i do it like this, i can't read my music on my ipod...how can i change settings like in the first picture??
(as you explain:
" - Storage path: \iPod_Control\Music (i can't change "F:" into "\iPod_Control\Music")
 - music files; F01\nnnn
 - audiobook files: \iPod_Control\iTunesPlaylists\Audiobooks
 - video files: \iPod_Control\iTunesPlaylists\Video")
Last Edit: October 01, 2021, 10:44:28 PM by robinwood
I'm the creator of the post you referenced. I'm sorry that I can't help you any further as I swore off all iDevices when my Classic got filled up. But I do have a few  questions:
Have you met the first two requirements?
Requirements
1 - You must use iTunes 9.2.1 available from http://www.oldapps.com/itunes.php.
2 - Your Classic must be at firmware 2.0.4, which is/was the original firmware for the Classic 6th Generation series.
And if so, perhaps try MB (Portable) v3.1 as that was the current version when I wrote the post. You can PM me and I'll upload 3.1 Portable Final to MediaFire or some other hosting site.. Old Versions post: https://getmusicbee.com/forum/index.php?topic=29783.0
Please let me know if it works so I can edit the original post.
If it doesn't work, perhaps there is someone out there who can provide an answer for you.
robinwood
WooooooooooowwwwwwwwwwWWWWWW Bro you just saved my life, it works now (even with the lastest musicbee version), i download the iTunes 9.2.1 (http://www.oldversion.fr/windows/itunes/ - French website -- if there is problem with installation, for instance "ipod service" i've done it on a windows 7 computer WITHOUT INTERNET CONNECTION!) as you told, download manually the firmware 2.0.4 (https://iosindex.com/ios/ipod-classic/3g/2.0.4-35) of the ipod, install it, changing sets of hard drive for ipod on Itunes and it work!!!!
Thanks  man!!! I can now use my ipod with 256Go!!!!!! Life is craaaaaaZzzzzzZZzzYyyyYyyyYYyyyYYyyy
Cheeeeeeeeeeeeeeerrrr
Last Edit: October 01, 2021, 10:48:29 PM by robinwood
Thanks for reporting. I'm really glad to hear that old post still works as long as one follows the requirements.
