Author Topic: When the panel open/close buttons are enabled, centre the summary statistics.  (Read 2984 times)
mrbenn
If I turn on the option to have buttons to close the side panels AND have "show summary statistics" enabled, the statistics are shown to the extreme right of the central panel.
If I do not have the buttons enabled, then the statistics are shown in the centre, which is where I expect to see them.
Is there any adjustment in the skin I can use, or is this something that would need to be changed internally.
