Author Topic: lyric panel synched ,can be customized the color of the fonts or skin dependent?  (Read 2632 times)
gaiastar
Hi
I have lots of songs with syncornized lyrics embeded as tag LYRICS
musicbee can read correctly and show them perfectly
the fonts are black and bold when in "karaoke" mode , i mean musicbee show the lyric in bold when are singed
is there a way to change the the bold "karaoke" color for example red , or the lyrics in gray and black when are singed
or the colors are skin dipendent
and there is nasty musicbee behavior , for example when i remove rating of a bunch of files or change the genre , musicbee does remove the lyrics stored in the tag LYRICS
I have reported but it's still present
i'm running MusicBee 3.4.7805
sorry for my english
in the screenshot you can see what i mean
thanks
stardepp
You go to MusicBee Settings - Layout (1) and scroll down until you see "Lyris". Then double click on "use costum color for highlightet text" and change the color as you like.
gaiastar
Hi
ohh , thank you so much , spend 1 hour to try to edit the skin and the there is the option in the preference :-[  :-[
appreicate it , thanks again
