Author Topic: Display trackslist of a mix  (Read 1128 times)
ebbremmer
Hello,
I've several MP3's which are mixes.
To display the track titles of a mix, I've created a .txt file containing the tracklist. How can I show these? I'm open to other solutionse.
Thanks.
Eric
Hmm, the simplest solution might be to put it in the comment field. Or lyrics might work well, since you probably won't have lyrics for the whole thing. If you want to get fancy you could probably make a cue sheet for it.
ebbremmer
Hello,
I've put a tracklist into the comments field and changed a panel to display it. Unfortunately, the list is not displayed.
Please, advise.
Thanks.
Eric
post screenshots of tag editor (displaying comment) and that panel.
