Hello everyone,
I'm using Musicolet to play music on my phone. Musicolet does not read MusicBee's ratings. It's also very annoying to import playlists through Musicolet, I gotta do it manually playlist by playlist.
I tried Gonemad which reads ratings and imports playlist easily enough, but I find it ugly, clunky, and I don't like it. Ideally I'd like to stay on Musicolet, or some other similar music player.
I thought about renaming my music files with their rating, something like "[4.5] Wolfmother - White Unicorn", this way Musicolet can sort by name. The playlist problem remains, and also I couldn't do this manually, I'd have to create a script that would read the rating and modify the filename accordingly and parse through all my playlist. And I'd have to run the script every time I change my song ratings through MusicBee. And MusicBee wouldn't understand where the files had gone which would fuck my m3u playlists up, unless I found a way to just change something in their metadata instead of renaming them (something that Musicolet could use).
Is there possibly an android app which can do what I want it to, or a trick that I could use to make it work with Musicolet?
Thanks!
