Author Topic: [FIXED]Album/artist text not visible in expanded album cover view in latest beta  (Read 2298 times)
Sigma
Version: 3.4.7925.16930
When you click on an album cover so it expands and shows the track listing, the album title, artist name, and year of release are no longer visible: -
A couple of examples: -
You can still click on where the artist name should be and it takes you to the Music Explorer tab, but the text is just not visible.
I have tried several different skins and it's the same with them all.
The bug is not present if I overwrite the musicbee.exe file with version 3.4.7918.19190, so I think it was introduced in the latest beta.
Last Edit: September 14, 2021, 03:02:47 PM by Sigma
Confirmed.
Not working with .7925 but does work with .7918.
Mr. Trev
Came here for this same problem…
Just a bit more info on my situation. I use artists view, and if there is only 1 album then the text isn't there - like what Sigma posted. However, if there is more than 1 album, the text will appear as expected
this should be fixed now:
Confirmed as fixed. Thanks Steven.
