Author Topic: Way to Manually set Number of Columns for Tracks  (Read 1078 times)
SomeDude
I'm somewhat new to Musicbee and was wondering if there is a way to  manually set the number of columns that the tracks are displayed in? I'm using the Album Covers layout where it makes a dropdown menu when you click in the album and I have the rating for the tracks next to them
https://imgur.com/t0tHflA
When I don't have the ratings the tracks are listed in three columns
https://imgur.com/3Pkxp8U
When I do have the rating it drops to just two columns
Is there a way to make it three columns and still have the ratings or something to that effect?
Welcome to the forum SomeDude
The number of columns depends on the width of the main panel.
If you are able to make it wider (e.g. by closing or making the side panels smaller) you will see that you get three columns with ratings enabled.
