Could we have the ability of adding a specific File Organiser preset to the customisable toolbar menu / assignable key.
Rather than bring up the FO window, it would immediately (or after a confirmation) apply that preset and move the files. If anything did not work, bring up just those files in the regular FO window.
Ideally, the preset and rules to be used when activated would be set and stored _independently_ of the stored presets in the existing FO presets drop down. This would make for easier management and editing of the rulesets.
My reasoning is that my library has about five sections on the disk that have subtly different naming schemes with their own rulesets that don't change, so skipping the FO window saves several steps depending on what I'm organising.
Thanks
