Author Topic: Not all albums and tracks displaying  (Read 1238 times)
NormB
For some reason my library is only displaying a small fraction of the albums I have in it and some of those are not displaying all their tracks.  The files are definitely in the library because a) I can find them with a search and b) if I navigate to them using "Computer" in the left panel, select a file and try to "send to", then "Music Library" is greyed out.
What might I be missing?
Thanks
There are so many different views and combinations of settings that you'll need to provide more information than that for anyone to narrow it down.
What view are you using? How did you add the tracks to the library? Was it working before and now isn't? Or has it never worked? etc...
At the very least a screenshot of what you're actually looking at.
Also search the forum - this question gets asked a lot.
Have you checked  MB's Inbox?
