Again, synching last played and ratings back from the player are a function of the wifi app and the two supported android apps (PowerAmp or GoneMad) working in conjunction, and that functionality has
Understood. I just used the "contact support" in PowerAmp about that issue. My point being that if I cannot get this info to sync in both ways then MusicBee does not fit my needs. It does not matter if the missing function is on the MusicBee side or the PowerAmp / Gone Mad site. If it does not work, it does not work.
I just started my last
test sync with PowerAmp as the player. I've been listening to music from the phone all day and noted down some of the tracks that had played. If they show up in MusicBee as played on 8/27, we have a winner. If not, I'll give GoneMad on the phone one cycle and if that also does not sync back, it'll be time to move on and maybe revisit if one or more of the mobile apps updates to address this.
When it comes down to it, it does not matter which side of the process fails the function. If it doesn't work, then it doesn't work.
nothing to do with that setting in the windows program's device settings because (for the third time) THE TWO SETTINGS ARE UNRELATED. The fact that you cannot turn on the setting in the windows
Now you're harping on something already acknowledged and topic-dropped.
