I tried using the Help, it's several versions old and does not match the program.
I tried searching the Forum, and got contradictory information.
I am not tech-stupid, I've been in IT support for 20+ years, but I know what I know and I do not know what I don't know. Some of this below, apparently falls under the "I don't know" category.
I cannot get my phone to show up and sync.
I'm looking to replace MediaMonkey on my Windows 10 PC and Galaxy S20+ (Android 11) phone. Due to my music library size, I need two-way syncing of smart playlists. I was pointed to the combo of MusicBee, PowerAmp, and MusicBee WiFi Sync. I have them all installed. I also have a USB cable to plug the phone into the PC as needed.
MusicBee has scanned my music library and added it to itself. Since it does not import from MediaMonkey (oh well), I have recreated some of my smart playlists and I'll do the others later after I get this next part working.
The WIFi Sync app says I need to run a wired sync at least once. Annoying, but OK. Plugged it in, and MusicBee does not see it. Even after restarting MuscBee.
Now what?
