Author Topic: Re: Add a tag value to multiple files at once, preserving existing tag values.  (Read 1576 times)
Windward
I am having a problem with adding a tag to multiple files.
I have 3410 tracks in my musicbee library. I have a text file made with MixMeister with all the BPM's on it. When I use "Copy Tag" from Additional Tagging Tools I get an error. The error says I have 3411 tracks in the text file but only 3410 in the library. I cannot for the life of me find out where the additional track info is coming from or how to add the BPM's.
I have done a "library Report" from Additional Tagging Tools and this shows the 3410 tracks I have checked the text file and that has only 3410 entries and I have tried several different methods of export (CSV, Text, Excel, Notepad etc.) and all have the same result.
Can anyone help? :-X  :-\  :'(
Windward
You're probably copying the new line at the end the text file.
I am not sure what you mean. I thought I had set up the copy/import as described in the forum post, but obviously I am not understanding what to do properly.
https://i.imgur.com/OpKVYYC.jpg
