Author Topic: Ratings  (Read 1077 times)
wildscapes
Maybe a silly question, is there a way either through MB or a specific skin where I can get a 10 star rating system as apposed to five ?
Nope.
You could set up an enumerated custom tag, but that won't be using star icons.
wildscapes
Thanks very much. I somehow didn't think so.....
Just to be sure in case you weren't aware, if you enable half star ratings, you do have 10 steps available instead of 5.
