This is in reference to MusicBee 3.3.7367 on Windows 10 Pro 20H2 (build 19042.1110)
I have my music library located on my PC and use MusicBee to catalog it.
I also have copies of most of the tracks on my Android phone.
I would like to keep track of which tracks I have on the phone and which I do not, so I used one of the custom tags. I renamed this tag 'Phone'.
I put a Y in the tag's value if the track is on the phone, and leave it blank if it is not.
Today I spent about 2 hours updating the values of the Phone tags on tracks in MusicBee.
I have been doing this by selecting multiple tracks of one artist, open the tag editor, and set the value for the custom (phone) tag to Y.
Then I hit Save, and move on to the next group.
I have also been moving some of the .flac files on the PC from one folder to another as I try to create a simplified directory structure. In the past, I have always stored files in folders by album, but since I am using MusicBee to sort out which tracks belong to which album, I am moving the flac files into a single folder for each artist. I never listen to albums anyway, so I just thought I would make my life easier - when I need to search in Explorer for a specific file.
When I make changes to the location of the files, I need to refresh MusicBee. I do this by File > Scan folders for new files.
Is this a bug in MusicBee, or am I violating some sort of rule of file integrity?
I am really frustrated with this now, so am planning to go back to my Access database for keeping my library organized, using MusicBee only for playing the tracks.
Any idea of what I am doing wrong?
Thanks
Ultrarunner
Edit: After posting, I recalled reading in these forums about saving custom tags to MusicBee database only or to permanent metadata in the files.
So I opened preferences and on the Tags(1) tab I see that I have my custom tags set to save to MusicBee database only.
So I chose one of the other options (File Owner) and selected it for the custom tags.
Now these tags no longer disappear if I move the files on the PC.
I assume that saving to MusicBee database only does just that - saves to a special MusicBee file somewhere on my PC (probably in Users/../Appdata.
This when the files are moved, and MusicBee rescans the music folders, these tags are reset.
I assume that by saving to 'File Owner' or any of the other choices in that list, I am saving the data to the file itself, thus it will not be lost if the file is moved.
Is this correct?
Thanks again.
Ultrarunner
