Author Topic: Additional Options for Creating Synchronized Lyrics  (Read 2359 times)
itori
Thank you for watching my post.
Can you please make it possible to select the format of the timestamp inserted by [Ctrl + T], which is used to create synchronized lyrics?
The default timestamp format in MusicBee is [m:ss.fff] or [mm:ss.fff], but I would like to change this format to a fixed [mm:ss:ff].
Example: [04:41:23], [11:00:00].
I often listen to music on my Sony Walkman. However, the [m:ss.ff] format does not read the lyrics correctly.
Therefore, I would be very happy if the format of the timestamp inserted by [Ctrl + T] could be selectable, or if the format of the LRC file could be selected when syncing files with the device.
On a different note, I tried to donate via Paypal as I use MusicBee a lot, but it was not available from Japan.
Do you have any plans to provide a way to donate from Japan?
PS: There may be sentences that are difficult to understand because I passed through translation software.
Last Edit: July 30, 2021, 03:26:24 PM by itori
