Hit a bug I've seemingly never encountered before in years of using MusicBee, have tried a lot of things to figure out what the problem is. Will try to keep it brief.
Windows 10
Latest version of MusicBee (non-portable version)
Have not recently moved my music library.
I noticed yesterday that my musicbee playlists were broken - none of the files were properly linked anymore, all red exclamation points. The files had not moved from their location. Click to play them, get a "Source File Could Not Be Found" error. This is only happening for the playlists I created in MusicBee as m3u files, not the auto-generated "top 25 tracks" etc - those are fine, the rest of the library is fine.
I keep all my music files in:
C:\Users\[user name]\Music\Old music\
Long story short, I open the m3u files in textpad and find out that for some reason, all my music files are using relative paths linked as:
Playlists\Music\Old music\[etc etc, the folders where the file should be and has always been]
Which isn't quite right. So, I edit the files using crtl+f Find and Replace in a word doc, paste it back into the m3u text file and hit save. The relative path in the m3u files is now:
Now, everything is fixed!
Except - when I "Add to Playlist" I uncover a problem. Even after fixing the m3u file, MusicBee changes the path within the m3u file so all of the music linked is broken again. Here's what happens:
The relative path that works:
The relative path that appears in the m3u file when I add any new song to the playlist, any of them at all:
\Music\Old music\[the correct path, etc etc]
Which means I have to edit the text m3u file all over again to get it to work.
This breaks the playlist for every song, again. I can't wrap my mind around what the problem is. I've tried "Re-link Music File Paths". I've tried re-scanning the whole library. I've tried flipping back and forth between m3u and mbp, moving where the playlists folder itself lives (right now I keep them in "C:\Users\[user name]\Music\" but that doesn't make a difference truly). I re-downloaded MusicBee to make sure I'm up to date, made no difference. There really isn't many other settings available to me that I can fiddle with that are playlist-only. I have not seen this issue anywhere else on the internet. I'm baffled by why musicbee playlists would overwrite paths that work and select relative paths that don't work. It didn't use to do this until this week.
Any help at all would be appreciated, thanks!
