Author Topic: Allow hierarchical and one-to-many genre to genre category mappings  (Read 2174 times)
leetaylor15202
Hey, long-time user, first-time wisher...
I've been spending some time lately getting my genres straight and thought of a couple of things that might come in handy.
1. The ability to create hierarchies under genres within a genre category. Example: Rock > Alternative Rock > Indie Rock > Post-Punk Revival. Under the current functionality, I can only map the sub-genre "Post-Punk Revival" directly to a genre category. If I map it to "Indie Rock," that creates "Indie Rock" as a new genre category. If I map it to "Rock," then I lose the sub-genres in between.
2. The ability to map a single genre to multiple genre categories. E.g., allow users to map "Dance-Pop" to both "Dance" and "Pop."
Really enjoy the app. Thanks for your consideration.
There's a newish feature called the Tag Hierarchy Explorer. I suggest you search that (Google might be easier than forum search) and see if you can't make it do what you want.
