Author Topic: Unexpected Error. when adding files to library  (Read 1860 times)
tantog
MusicBee v3.4.7805.33439D  (Win10.0), 20 Jul 2021 12:41:
System.InvalidOperationException: Unable to retrieve security descriptor for this frame.
   at System.Security.SecurityRuntime.RevertAssert(StackCrawlMark& stackMark)
   at System.Security.CodeAccessPermission.RevertAssert()
   at System.Windows.Forms.WindowsFormsSynchronizationContext.Uninstall(Boolean turnOffAutoInstall)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at #=zsSqWEB_uCfYs1RIo5gmlWEiXxs7c.Main(String[] args)
Is this reproducible?
Does it happen every time you try to add any music file to the library?
Or does it only happen some times?
And if some times, it it always the same file?
How exactly are you adding to the library?
Step-by-step please.
that doesnt look like a direct musicbee error. It could be a few things but as a guess it might be your security software interferring with MB - try whitelisting MB in that software
tantog
Only happened once, thus far.
