Author Topic: Same album, different format  (Read 898 times)
nzlowie
Hi again team
Another newbe type question.....
I have several albums from the same artist with the same album name but different format, say,  Wav and DSD. How can I make sure all versions of an album are visible?
Cheers Dave
What do you mean by "visible"?  They should always be visible.  Are you not seeing all of the versions in MB?
If you're talking about grouping them only kind with kind, then you'll either need to disambiguate them in the album title tag field (i.e. Album Title [WAV Version] vs Album Title [DSD Version]) or in an unused or custom tag you use specifically for this kind of disambiguation.
nzlowie
Thanks Frankz
Thats what I was looking for, makes perfect sense now you mention it!
Appreciate the advise.
Cheers Dave
