You really need to provide some more details in order to get some help. Most importantly, what plugin are you trying to download and from where?
You can use a USB cable between the phone and your PC to sync your music. You don't -need- a plugin.
There is a plugin that provides syncing via WiFi, and typically is a faster sync than USB. It is available from the Google Play store. Look for MusicBee WiFi Sync.
