Author Topic: Kryptonite Dark  (Read 6019 times)
Ingo_Igel
I started this little project for my own, but it came out so well that I wanted to share the result with You.
This theme is based on the Windows 10 dark theme colours and a touch of Winamp Classic.
--> Download v 1.0
Install Instructions:
Place the file in your Musicbee/Skins folder and select it in Musicbee under View > Skins.
Information: By changing the color variables in the xml file, not all icon colors will change.
Known Bugs/Issues:
Update 1.0
- New suitable "LargeTick" image
- New suitable "OpticalDriveIcon" image
- Cleand up code
Update 0.9.3
- New suitable "CheckTick" image
- New suitable "CheckTickDisabled" image
Update 0.9.2
- "Controls.ProgressBar" elements have been commented out.
Please feel free to comment and give feedback.
ENJOY AND HAVE FUN!
Thanks to hiccup for his Sample Skin
Thanks to Muvikui for the no album art (CC-BY-SA 4.0)
Last Edit: July 16, 2021, 04:59:16 PM by Ingo_Igel
Thanks for sharing your work!
(and welcome to the forum)
Known Bugs/Issues:
- "IconColourOverride.Default" is overriding the colour of the chekmarks in the menus.
- If the Track Information is selected in the now playing bar at the bottom panel, I have no idea how to change the font colour.
- I don't know how I could test the three "Controls.ProgressBar" elements or where I find them in Musikbee.
1. If you want to override the checkmark, you need to use a 16x16px image file, encode it to base64, and copy it in your skin.xml under 'images' as  <element id="CheckTick">
   (a forum search should lead you to how that can be done)
    You will probably also want to define others such as "CheckTickDisabled", and "LargeTick". (for the Panel Configuration panel)
2. Over the years, the functionality of that panel has changed a little bit, and I am not completely sure how it is controlled at the moment, but far as I know the text colour is auto-generated depending on the background colour.
3. These are obsolete (as far as I know)
   If you check the paragraph at line #10 of my sample skin you can read my current understanding/handling of those.
Last Edit: July 13, 2021, 06:53:55 PM by hiccup
Ingo_Igel
Known Bugs/Issues:
Thank you for your help hiccup.
I added/deleted everything as mentioned.
