Author Topic: AT&RT Plugin error: "Unable to initialise plugin: mb_TagTools.dll"  (Read 9892 times)
There is very common error for "Additional Tagging & Reporting Tools" plugin, which haven't succeeded to fix:
Unable to initialise plugin: mb_TagTools.dll Exception has been thrown by the target of an invocation.
This error is probably relates to corrupted plugin settings file. To fix this error:
1. Close MusicBee
2. Delete file <MusicBee AppData Folder>\mb_TagTools.Settings.xml
3. Start MusicBee again
<MusicBee AppData Folder> depends on MusicBee version you are using and may be "C:\Users\your username\AppData\Roaming\MuiscBee" for MusicBee installer version or "<MusicBee Installation Folder>\AppData" for portable MusicBee.
Sometimes this advice may help in case of other plugin errors.
Please provide any bug reports on plugin main thread.
Last Edit: July 11, 2021, 12:54:44 PM by boroda
