Using MuscBee portable. I just copied all my media from one drive to another. All the files on the new drive have exactly the same paths as the old drive. The only difference it the drive letter. I do not want musicbee to move anything. I have 4 separate libraries. Editing them via the musicbee settings is a bit of a pain for me because for every library I have to re-click the location of each set of files that are part of the library.
So to get to my point, can I simply open each library file (\Musicbee\Libraries\<library name>\MusicBeeLibrarySettings.ini) and change the drive letter from the old one to the new one? All I have to do is a simply search & replace command changing the old drive letter with the new one. Will this do the trick? Is there some other file or settings I need to change?
