Author Topic: Rename/Correct tags  (Read 1309 times)
Bodtje
Hello,
I've been searching for some time but can't find a solution to this problem.
I've got a big classical music library and created some custom tags for it. Now some of these tags contain errors.
E.g. in my Conductor tag the same conductor Gerard Schwarz is sometimes written as Gerhard Schwarz.
Is it possible to correct this throughout my entire library without having to search for and select each erroneous tag?
Thanks in advance,
Bodtje
Select Composer in the library thumbnail browser menu. Find the misspelled composer in the list and select it.  This will show the files that are tagged with this composer in the main window. Select those files, Shift+Enter brings up the tag editor, correct the spelling.
Menu screenshot from Wiki below.
Last Edit: June 07, 2021, 05:28:35 PM by frankz
Bodtje
Hi frankz,
thank you so much for your quick response. This worked flawlessly and was a great help.
Cheers,
Bodtje
