Author Topic: Shutdown while open does not remember last position  (Read 5328 times)
StevensNJD4
Hello,
I have "on startup: resume position" enabled and by force of habit, I shutdown with everything open. When I start MB on next boot, it resumes the last position of when I last actually closed it. This did not happen on v3.3.
Version 3.4.7805
Regular installer
StevensNJD4
Please get a better CAPTCHA service. Holy hell. Took 3 refreshes to post this.
working fine here and nothing has been changed for that functionality since v3.3
If you mean shutdown windows without exiting musicbee and windows classifies it as a critical shutdown, then v3.4 will not attempt to save the settings file (MusicBee3Settings.ini) to avoid file corruption.
Could it please be an option?
That looks like asking for an option to possibly introduce file corruption.
And all that because you don't want to close MusicBee properly, and after starting MusicBee the next time, it starts playing the last song that played fine before MusicBee was forcefully shutdown.
Seems like both an invalid bug report, and an inappropriate request to me.
you will either change how you shutdown windows - its only when windows needs to shutdown without allowing apps to save data that MB skips the settings save or go back to using v3.3
jewahe
I just signed up because I have a similar issue. I like to have music playing while I sleep. So I have a Windows task to launch Music Bee at 9pm, and a separate task to shut it down at 9am. Music Bee is configured to resume playback (not position). This worked fine for a long time, but then about a year or so it stopped working, and I have to manually start the playlist again every evening.
I don't care that it starts from the previous position, only that it starts playing again.
This feature must be able to deal with unexpected shut downs.
The developer directly addressed the issue of improperly shutting down the program and gave mitigation suggestions in the post right above yours, so I'm not sure what you hope to accomplish reiterating the problem.
Task Scheduler shut downs are like killing the task from the Task Manager. It is not the proper way to close a program. MusicBee has a timed shutdown feature (File->Activate Auto-Shutdown) which closes the program properly on a timer.
Last Edit: June 10, 2021, 05:44:45 AM by frankz
jewahe
1) I posted in agreement with the OP that the program does not properly handle unexpected shutdowns.
2) I know how Task Scheduler works (which is why I used the term "unexpected shutdown").
3) Using the Task Scheduler process worked for me for a long time, until it stopped working about a year ago. Obviously, something changed.
4) I tested the Activate Auto Shutdown feature, and it does NOT persist across sessions. So that means more manual intervention on my part. That's the whole reason I use the Windows Task Scheduler in the first place - I wanted Music Bee to start prior to by bedtime and shut off the next morning. Again, this process worked fine for around 2 years, but stopped working about a year ago.
5) The obvious conclusion is that Music Bee needs better support for unexpected shutdowns (something Windows is notorious for) or needs a better scheduler.
As was explained by the developer in the post directly above your first post, the the result you're seeing in later versions is the "better support for unexpected shutdowns." Prior to this change, a risk of corrupted files existed.  Problem solved.
If you'd like changes made to the scheduler, that could be posted to the wishlist.  I'd probably even +1 some updates to that functionality.
jewahe
To be frank, if what you're saying is true, the "fix" broke established functionality and needs to be revisited. As I said, Windows is well-known for being flaky. I expect better from knowledgeable developers.
Last Edit: June 11, 2021, 04:12:27 AM by jewahe
I'm sorry that having to manually press play happened to you, and I hope you're OK.
jewahe
I posted a thread in the wish list, but I still think it's a bug that needs to be addressed. I understand that the last position/time index cannot be recorded at the point of an unexpected shut down, but the last played track should be written to the database/log which can be used as the starting point upon restart.
My issue is that not only doesn't Music Bee remember the last played track, but it also DOES NOT resume playback. I can deal with the former issue, but the latter issue is a serious issue.
