Author Topic: Post Win10 Crash  (Read 1163 times)
portnoy
MusicBee v3.3.7491.38139D  (Win10.0), 2 Jun 2021 17:58:
   at CubeIsland.LyricsReloaded.LyricsReloaded.shutdown()
   at CubeIsland.LyricsReloaded.LyricsReloaded.Finalize()
The error is being caused by the Lyrics Reloaded plugin. It's possible you don't have it installed correctly. Further questions regarding the plugin should be posted on the plugin's thread so the plugin's developer can see them.
I would also suggest updating to the latest MB 3.4 release. What you're using now is about a year old. See my signature.
