Author Topic: Auto search when manually adding artwork.  (Read 1498 times)
SurfRat
Been using MusicBee and MediaMonkey to update my tags and artwork. I the auto tag does not find the artwork I end up adding it manually. MediaMonkey has a killer feature for doing this in that it searches for you and saves a lot of time.
Here is the edit artwork dialog in MediaMonkey:
https://drive.google.com/file/d/1Gx5BZwKcprysV-QrOuu24qyyHQ1KKW6X/view?usp=sharing
and
https://drive.google.com/file/d/1OgLiH9d9INv-ZCXn6gXBxmZZ74DeJnP9/view?usp=sharing
MediaMonkey makes it so much easier.
Could you please consider adding something similar.
Thanks
This already exists. Tools > Artwork > Downloader
SurfRat
I just ran a test and it did not work for me. I admit my sample set is not mainstream.
MediaMonkeys search is a lot looser and gives more results.
If I could add more screenshots I would. This forums no upload policy is a real pain!
"this forum" does not have a no upload policy. It is the function of the forum software that is being used (Simple Machines Forum.) There are instructions all over the place on how to upload screenshots. I suggest the next time you post/reply that you read the 'NOTE" just above the edit window.
