Didn't see anything relevant. My library has hundreds of books, many in series, I found this naming scheme works well with a library at root level of external drive.
*<Album Artist>\$IsNull(<Grouping>,<Sort Album>,<Grouping>\$IsNull(<Series Issue>,,"Book "$Pad(<Series Issue>,2))$IsNull(<Series Length>," - "," of "$Pad(<Series Length>,2)" - ")<Sort Album>)$If(<Disc Count>>1,", Disc "$Pad(<Disc#>,2)" of "$Pad(<Disc Count>,2),), Part <Track#> of $IsNull(<Track Count>,,$Pad(<Track Count>,2))
Normal Tags Grouping: Series Name
Album: Book Title
Title: Chapter Name (if chapters are not named, use numbers or the book title) -- not part of file naming scheme
Custom Tags custom 1: Series Length (the total number of books in a series)
custom 2: Series Issue (the ordinal designation of the book in the series)
custom 3: Literary Genre (to avoid confusion with musical genres)
<Album Artist>\ --
Put it in a folder with the Artist's name$IsNull(<Grouping>,<Sort Album>, --
If the file is not part of a Series, name the file after the Book<Grouping>\ --
otherwise, put the file in a folder with the Series Name$IsNull(<Series Issue>,,"Book "$Pad(<Series Issue>,2))$IsNull(<Series Length>," - "," of "$Pad(<Series Length>,2)" - ")<Sort Album>) --
To keep the books in Issue order, preface the file name with the Book Issue# followed by a hyphen and the Book's name$If(<Disc Count>>1,", Disc "<Pad(<Disc#>,2)>" of "<Pad(<Disc Count>,2),), Part <Track#> of $IsNull(<Track Count>,,<Pad(<Track Count>,2)>) --
then, add the disc number, if more than one, and label the track number as PartBest example is from a CD set of the Lord of the Rings
\Audiobooks\J.R.R. Tolkien\Lord of the Rings\Book 01 of 03 - Fellowship of the Ring, The, Disc 02 of 16, Part 14 of 23 * The extra texts (Book, Disc, and Part) can be removed or abbreviated to shorten file names, if necessary.
