Having finally populated my MB podcast shows list (more than 1000 shows), I closed MB and was going to open it and backup everything.
Instead, I got the message that
Podcast updates are locked until the next MB restart - unable to access subscriptions.dat
This subscriptions.dat is 70MB large, and takes more than 12 hours for MB to import (that's another annoying thing I can't quite figure out, but that's another matter).
Is there any way of recovering my subscriptions? I literally have a subscriptions.dat from another run hanging around, pasted it into the folder of the library of interest, and nothing is happening.
If I tried to ask for updates to subscriptions this error mesage comes up
MusicBee v3.4.7764.37422P (Win10.0), 6 May 2021 23:30:
at #=z1v6HwQ___W9fot3mUPBSD6cwyKsC.#=zxiGRFaFOGvGcFIrbyw==.#=zHBgv5FU=()
at #=z1v6HwQ___W9fot3mUPBSD6cwyKsC.#=zxiGRFaFOGvGcFIrbyw==.#=zLxF5cBkoJO1V(IList`1 #=zO609_$Q=, TagCode #=zcqqWz3k=)
at #=z1v6HwQ___W9fot3mUPBSD6cwyKsC.#=zLxF5cBkoJO1V(IList`1 #=zO609_$Q=, TagCode #=zcqqWz3k=, Boolean #=zLj9cBNQb1vDc)
at #=z1v6HwQ___W9fot3mUPBSD6cwyKsC.#=zad6rLdU=(ApplicationCommand #=zXlo3vTk=, Object #=z46QPSpU=, #=zq6NWNemGKQIaa6EjwRusDx8= #=zO609_$Q=)
at #=zSl3nx0ysuCOud6pBLQbkG83fN5Ji.#=z8HTLpNI=.#=zOKD_7mM=(ApplicationCommand #=zXlo3vTk=, Object #=z46QPSpU=, IList`1 #=zO609_$Q=)
at #=z91BnV_J$yVShjfWflQwofAw=.OnClick(EventArgs #=zp6b9u0U=)
