Author Topic: Now playing only shuffles one album  (Read 976 times)
FMcac
When I add albums to the now playing list while set to shuffle, only the first album plays (shuffled), and then musicbee stops.
I assume you are using v3.4
this should fix the issue:
I suggest you re-download as the implementation has been improved
