Hello,
since more then one month now I've experience constant crashes when starting Milkdrop visualizer.
Steps to reproduce :
1. MB Visualizer is set "Milkdrop 2.2"
2. Press "V" to start visualizer
Result: "Window resize failed" > MB crash
(there is no difference when set to "Fullscreen" or "Normal" (tab))
Workaround:
Unknown so far - sometimes (20% chance) Milkdrop is just starting fine, without crashing MB!
This behavior did never happen 2 or 3 month before and unfortunately I can't say if it is now caused by a recent ...
- MB update
- Windows update
- AMD Adreanline driver update
Any one here who is facing the same issue too or already has resolved it ?
Greetings.
MB 3.4.7754
AMD Andrenalin 21.4.1
W10 20H2 Built 19042.928
(effort-benefit ratio for rolling back one of the mentioned updates unfortunately will be a pain and isn't intended by myself)
