Author Topic: Slow opening WHMT radio stream  (Read 528 times)
gojets46
I use the internet radio function of MB daily, all other stations work fine.  But for some reason the WMHT stream takes about 45 sec to start playing.  It seems to be just this station (https://wmht.streamguys1.com/wmht1.m3u?rn=8107&file=wmht1.m3u), same result with (http://opml.radiotime.com/Tune.ashx?id=s31022&formats=aac).  Any clues? Thanks
gojets46
Oh - windows 10.  A squeezebox touch works ok with the url.
Both of those streams open almost instantly here.  As both are AAC try adding bass_aac.dll to your MusicBee main folder; see: https://getmusicbee.com/forum/index.php?topic=23454.0 .
gojets46
Adding 32 bit bass_aac.dll did the trick - thanks
