Author Topic: Moving to a new computer - tutorial?  (Read 607 times)
zkg66
Hello, I'm curious if there is a step by step tutorial anywhere that show how to move MusicBee from an older computer to a new one.  If someone could point me in that direction, I would greatly appreciate the help.  Thanks in advance!
There isn't a tutorial, but using MB's portable installation makes it quite easy. Copy the entire MB directory to a flash drive and copy it from the flash drive to the new computer. You do need to make sure the paths to your media files is the same on both PCs.
You should also search the forum to see how others have done it.
Check out the MusicBee Wiki.
