Author Topic: Playlists Not Accessable via Apps when casting MusicBee, PC to MusicCast  (Read 595 times)
Etnmtnhome
My Playlists do not show up on my MusicCast app or Hi-Fi Cast App. (I can access my music via Artist, Album, etc. via the Apps)
I recently installed MusicBee, organized my FLAC files, and activated Windows Media Sharing. My Playlists are in my "Playlists" Folder, within the "MusicBee" folder, within the "Music" folder in both my Documents and Library.
This isn't a big deal, but the "Ratings" don't show up in the apps either.
As you can probably tell, I'm Not at all knowledgeable, hopefully a simple answer will get my Playlists up and playing!
Thanks in advance
How was MB installed? (Installer, Portable, Store)
I just started playing around with Hi-Fi Cast and my playlists are showing.
Etnmtnhome
phred,
Version 3.37491
Installer, (about a month ago)
FWIW, as an "experiment" I temporarily installed "Windows Media Center" ...the Playlists were available on that app... but no ratings  (I've since deleted the program)
Thanks
Hmmm ... you're using a fairly recent version. And not using the Store version. I can't recall anything along these lines changing between your version and the current. So I'm at a loss for an explanation.
Hopefully someone will come along with an answer or more questions in an attempt to figure out what's going on.
