The desktop app has been buggy for me lately. The biggest issue is that the audio goes out after I pause a track and try to play it again. The audio is working fine before the pause, but doesn't work at all when I try to start playing again. The track is playing (as evidenced by the status bar), but there's just no audio. As I was hunting around for an option to update the app or troubleshoot this issue, I randomly decided to change the skin. The app immediately crashed (error code copied below). These two issues could be unrelated, but it just seems weird that two problems would occur simultaneously. Is my only option to uninstall/reinstall since I can't open the app at all right now?
MusicBee v3.3.7491.38139D (Win10.0), 5 Apr 2021 9:04:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at #=zgUgQa1gfdKrsF5glDLpI6M2jBAX6.#=zIhNqFwupHQ3A.#=zcapMatMJwoW3wXBHTA==.#=zDA7hHG93DNXX()
at #=zgUgQa1gfdKrsF5glDLpI6M2jBAX6.#=zIhNqFwupHQ3A.#=zcapMatMJwoW3wXBHTA==.#=zdtsEQ7M=(Boolean #=zilCtaZg=)
at #=zgUgQa1gfdKrsF5glDLpI6M2jBAX6.#=zIhNqFwupHQ3A.#=zcapMatMJwoW3wXBHTA==.#=z4xuk3M4vAv88()
at #=zgUgQa1gfdKrsF5glDLpI6M2jBAX6.#=zIhNqFwupHQ3A.#=zsKZqSNHOVDey(Rectangle #=z$KHBYHk=)
at #=zgUgQa1gfdKrsF5glDLpI6M2jBAX6.#=zl8Oc$QrEiN2d(#=zKtX4yvmPH1xm #=zyhCG_yI=, Boolean #=zdjn4vojI8vvXNzK7nw==)
at #=zgUgQa1gfdKrsF5glDLpI6M2jBAX6.#=znqM$Q0OioJwf(#=zKtX4yvmPH1xm #=zyhCG_yI=, Boolean #=zdjn4vojI8vvXNzK7nw==)
at #=zgUgQa1gfdKrsF5glDLpI6M2jBAX6..ctor()
at #=zgeY_Na03jtcNMBza84h0RpVbwUy0.Main(String[] args)
