Author Topic: Playcount 0  (Read 2239 times)
Luysita
Hello,
When I first installed MusicBee, I was able to see which musics haven't been played on the Playcount (which showed 0) but now I can't see them anymore.
Not sure if it was a setting I changed or simply a bug?
How can I change it back?
Thank you
jonap
right click on the columns header > set displayed fields
chose play count, or last played, or other useful fields you may need
Luysita
I got the field activated, it's just not showing songs that have 0 playcount. It used to show before though.
If you sort your music library on this field by clicking it in the header, it will show all the songs with the lowest play count first.  If there are any that have 0 plays, they will of course be on top.
If you're looking somewhere else and not your music library for this information, then you will need to be more descriptive about where you're looking and post a screenshot of it.
If you're going to be vague about what you're doing and where you're looking, then you're naturally going to get generalized answers.
Have a nice day.
Luysita
I'm not trying to be vague, english is not my first language and I don't know how to explain things better, I apologize.
music bee is not showing songs on the software that i haven't played before, not sure if it was a setting I changed.
Example
I got this album that I only played one of their songs:
It only shows the playcount of the song I played, doesn't show the songs I didn't play
Hope my explanation makes more sense now.
Last Edit: April 02, 2021, 03:46:56 PM by Lapis
Have you looked at Properties in the Tag Editor? I don't display play counts, but I see a zero under Properties.
You could create an auto-playlist where play count is zero and that will show you the tracks with no plays
Do you have a search active in the search box at the upper-right?  Unless you clear your search, it will remain active.
Also make sure you don't have any filters active for that tab.
Luysita
I looked at the options and found nothing.
I'd rather just keep it on my playcount tho.
Luysita
I do not.
I don't know why you're looking at options when I said to look at Properties in the Tag Editor.
Luysita
What am I looking for?
To see if play count is showing as zero. And it is.
So I have no idea why tracks with a zero play count are not showing up unless you're filtering them out.
