Author Topic: Synced lyric timings.  (Read 1058 times)
Danielj
Hi, is there a way to offset the syncronized lyric timings? When adding timestamps I'm generally pressing it slightly too late, so it would be nice to add an offset that makes the timing earlier. It also seems like the timing is slightly later than when I actually press the timestamp key.
In the metadata of each lyric, like the artist or title, you can put [offset:500] or [offset:-500] or something like that (in milliseconds) to push the lyrics up or back by that amount.  There is no global setting.
Danielj
Thanks, guess I'll have to add that every time I'm doing lyric timings.
I suggest you first update to v3.4 from the first forum topic as i recall some changes were made to the timings
