Your comment doesn't track.
Occasionally the shuffle gets stuck on an album...
Often it favors an artist...
Sometimes it repeats songs...
Actually, it does none of those things.
If you start MB and shuffle a playlist or your library, a Playing Track list is created. Assuming each song in the playlist/library exists in the playlist/library only once, each song is only in that list once.
If you've set MB up properly for what you want to actually do with MB (Edit->Edit Preferences->Now Playing...clear playing tracks list and current playing track on restart is OFF), that list is not changed when you restart MB. The last track is in the past, the next track in the list of 7774 is queued, you hit play and you're off to the races.
If you're restarting the process by going back to the beginning and re-queueing all of the tracks, why are you doing that? You already have a list where all of the tracks are only represented once and will only be played once until the end of the list.
Asking as a friend
