Author Topic: [Solved] Search field in the shortcuts panel  (Read 1806 times)
ClementNerma
Hi!
A feature I feel like is missing from the shortcuts panel (Edit Preferences > Shortcuts) is a little field to search for a specific shortcut, as there are many of them, and in some languages like french the shortcut titles are very long so it's a bit tiring to read the entire title of each shortcut one by one in order to find the good one.
Thanks in advance! :)
Last Edit: April 26, 2021, 05:19:25 PM by ClementNerma
If by "shortcut" you're referring to "Hotkeys" there already is a search box. If you don't see it
How was MB installed? (Installer, Portable, Store)
Check out the MusicBee Wiki.
ClementNerma
Weirdly, I didn't get a notification for your answer (maybe a problem with my inbox).
I currently don't have the search field:
I'm currently using MusicBee version 3.3.7367, installed from the official website's Windows installer.
You need to apply the latest 3.4 patch in order to get the Hotkey search box. See my signature.
ClementNerma
