Author Topic: [Solved] Setting the default font size in the Lyrics popup  (Read 1895 times)
ClementNerma
Hi!
I'm using the lyrics popup very often to check the lyrics of a song, but I find the default font size too little to be readable on my screen. The "+" button on the bottom right allows to set a more readable font size, but it needs to be clicked on every time the popup is opened again, as this is not a setting that is remembered.
I wondered if it would be possible to make the selected font size memorized by this popup? Or alternatively maybe a setting with the default font size of this popup?
Thanks in advance for your answers :)
Last Edit: April 26, 2021, 05:19:16 PM by ClementNerma
What do you mean exactly by "lyrics pop-up"?  Are you referring to having the lyrics display in a floating window, or some 3rd-party lyrics plugin?  The font size for lyrics in the default MusicBee lyrics panel is adjustable--drop the header menu on the lyrics panel, choose "Customize Panel," and you'll see this:
ClementNerma
Sorry for the later answer,
I'm talking about the floating window that can be assigned a hotkey to:
Did you try adjusting the default lyrics font size in the place I indicated in my last post?
