Hi all, I am new here and also new to MusicBee, So far it seems ok. I used to use Daum Potplayer but sadly they are pumping out annoying ads that flash up on your desktop and i hate apps with adware & malware. Also i heard Potplayer isn't secure hence the reason i have switched to MusicBee.
I don't want to sound ungrateful but i have a problem already.. I have set MusicBee as my default in Win10 but If i have a folder with 30 songs in it and highlight all songs, Select "Play All" tab only half the song will load in the track list. I thought it might be the folder or maybe some MP3 files were corrupt but it does it on other folders i have tested.
Am i missing something why it's not loading all songs in the play list on the right hand pane?
Thanks
